BUG: 24-bit albums showing as 16-bit (but sample rate correct)
Serento displays all bit depths over 16 (24, 32) as 16 for files hosted on my local Lumin L2 server. For example, 24/96 albums display as 16/96. 24/192 albums display as 16/192. For some reason, Serento gets the sample rate correct, but not the bit depth. Because of this error, all albums are displayed as CD-quality, not HiRes, and Serento isn’t able to show an average bit depth on the statistics screen.
Server: Lumin L2
Renderer: Lumin U2
Hi @washdcguy,
I have found the issue. Serento treats anything with no bit depth info as 16 bit. It seems there was an issue reading the bit depth from your files. In any case, I changed how the format badge is calculated so that your files are displayed as high res.
The fix is going to be in the next update.
Thanks for reporting this issue.
All my music files are missing bit depth rates? That seems unlikely, as I’ve purchased a number of them directly from Tidal, Qobuz, or Bandcamp. How can I fix my files so Serento accurately identifies the bit depth rate?
@washdcguy your files will all have that info - it’s baked into the media headers in almost all file types, it’s possible that the Lumin server isn’t advertising that data in a way that a control point app like Serento can read though.
That is exactly what is happening. Lumin has a setting for this and if it’s off it will not send the bit depth.
I reached out to Peter, the head firmware guy at Lumin. I can’t find the bit-depth-sharing setting you’re referencing, but maybe he knows what you mean.
With version 1.1.4 it should be ok. Have you tried?
did you just release a new version? unfortunately, i’m at work. i’ll definitely test it out tonight.
Yes, yesterday I released 1.1.4 with a fix for your issue. Let me know if it works. Thanks.
I like your solution. But part of me feels like it’s cheating :rofl:. I wish Lumin would share the appropriate bit depth rates with Serento.
If you consider anything above CD quality as high res then it’s not really cheating. :smiley:
The only downside is that you don’t see the bit depth.
