I just added an album today which is showing the different CDs as CD 1 and CD 2 - I will send a log.
It’s “Adagio for Strings / Violin Concerto / Orchestral & Chamber Works” by Barber; St Louis Symphony Orchestra, Leonard Slatkin, Elmar Oliveira.
All my other multi disc albums only show the different discs when there’s a Disc Subtitle.
I’ve checked the tags to see if there’s a weird disc subtitle tag but there is not.
Hi @tiefling,
Thank you for the report and the log, they made this quick to trace.
What you see on the Barber album is how Serento shows every multi-disc album: when the files carry a disc number above 1, the tracklist gets one header per disc. If the disc has a DISCSUBTITLE, the header shows the subtitle; if it does not, it shows CD 1, CD 2 and so on, and the capsule plays that disc.
Your other multi-disc albums in the log (re:member, Collaborative Works, Englabørn & Variations) all have disc subtitles, which is why you only saw their names there. The Barber set is a real 2-CD release with disc numbers in its tags but no subtitles, so its headers read CD 1 and CD 2. Nothing is wrong with your tags.
Yours,
That’s not true with MinimServer though - it combines the discs and publishes the album with a continuous track list and absolute track number.
None of my other albums on multiple discs, without disc subtitles, are doing this and it appears to only look this way on Serento - mConnect is listing the files using the absolute track number.
@lorin.bute what if this is happening because, in this case, the album with multiple discs ALSO has groupings.
I can’t think of any other albums I have that have groupings on multiple discs that don’t have Disc subtitles.
I can’t see anything that seems different server side, so perhaps the Work grouping is clashing?
