Sorting Composers by Name is unpredictable.
It used to seem surname based but now it’s a bit all over the place - this is a clear side effec of the fact that more composers are now appearing. My current order reads:
- Adam Wiltzie
- Agustin Barrios Mangore
- Alfred Newman
- Anne Muller
- AR Rahman
- Arthur Jeffes
- Atticus Ross
- Johann Sebastian Bach
- Bela Bartok
- Bear McCreary
- Ludwig van Beethoven
- Ben Lukas Boysen
- Benji Merrison
- Leonard Bernstein
- Georges Bizet
- Alexander Borodin
- Johannes Brahms
- Brian Eno
It seems the older / pre-modern composers seem to sort by their surname (Ludwig van BEETHOVEN) but the newer ones don’t. It’s not a 100% thing - there are less well known period composers that are NOT sorted by surname “Gaetano Donizetti” is one.
Preferred logic for this would be to either work out what the surname is with simple string splitting to the last available part as a fallback. It own’t be perfect but it’s probably around the 99% mark. The Composer Sort tag is another option, but it’s not often the most reliable data - particularly when multiple composers and arrangers start rearing their heads - Looking at mine was my first call before I logged this bug (enough to determine it wasn’t their fault but to realise sorting them would be… unpleasant).
If the above would get us 99% of the way there then you can add a later catch for anything odd by allowing users to set a “Sort As” on a composer (or anything for that matter) which overrides - My Vinyl collection tracking app does something similar and I use it for weird personal stuff, so I can do things like track solo works by band members sorted so they come just after the band, so I sort “Steve Hogarth” as “Marillion (Hogarth, Steve)” instead of “Hogarth, Steve” which reflects how I store my records. This is an edge case bonus feature though so I’d probably make it way out of scope of the bug.
