On the iPhone you can select a work, see what albums its on and you can open up the panel to see what parts the work has. It’s nice.
On the iPad this is broken - There are no parts showing in the panel and clicking the album cover doesn’t do anything (on the phone it loads the album in the normal view)
Does this happen with all the works?
I’m asking because I can’t reproduce this issue on my end. So, I’m wondering if it’s an issue with a specific Work.
Possibly not - I’ll check but it may vary much like the differences I posted under the other bug / be another symptom of the same underlying issue?
@lorin.bute I can confirm that, like the other issue with Works / Movements that differs on the iPad this also works when the tags are very limited but seems to break when the tags are full detail from the Classical Extras Picard plugin.
I’ll add more on this to the other post
