BUG (Minor): Composer Separator
An album with 2 composers - Dustin O’Halloran; Adam Wiltzie is displayed by Serento as Dustin O’Halloran, Adam Wiltzie and they are treated as a single composer as an entity rather than 2 individuals.
This has been fixed in the upcoming version.
This is still behaving the same way - The 2 composers are being regarded as a single entity - “Dustin O’Halloran, Adam Wiltzie”
Hi @tiefling,
Thank you for checking again, and sorry, you were right: it still behaved the same way.
The earlier fix only handled composers that the server sends as separate values. MinimServer sends all the composers of a track as one value, joined with a comma (“Dustin O’Halloran, Adam Wiltzie”), so that fix never applied to your library.
The next update reads MinimServer’s own Composer index and uses it to split these credits. A name stays whole when it is clearly one person (“Bach, Johann Sebastian”, “Harvey Mason, Jr.”). Dustin O’Halloran and Adam Wiltzie will each have their own composer page, and their shared work will appear on both.
Thanks again for the report and the logs, they made the cause easy to find.
