BUG (Minor): Unintentional Grouping
I opened up a Prince deluxe edition yesterday and one of the discs has multiple edits and remixes for each track.
This revealed a small issue with the grouping in album view.
If a track has a Work tag filled out then any sequential tracks that follow with the same work tag group. 95% of the time this would be correct, but where there is no Movement Number or Movement tag set alongside it you can get situations like this when different versions of the same Work are grouping rather than when they are parts of a Work.
When grouping, the grouping should probably only happen when there are Movement or Movementnumber tags set.
I’ve noticed this before but in a less jarring way - One of my Tubular Bells versions, for example has 3 tracks - Part One, Part Two and an Intro Edit. I’d wondered why this was grouping all 3 tracks, when Parts 1 and 2 were the only parts in the Movement sequence, but this would explain it, as (in classical terms) the edit is an alternate arrangement/ variation, the Work is the same, but it shouldn’t be part of the grouped sequence, which is just Part One and Two in this case.
This has been fixed in the next version.
Thank you for reporting it.
