When you have a single movement within a work where a second composer is involved, this breaks the work. The grouping breaks in album view and the Work view is split into 2 works with the same name.
This can happen - Examples:
- Max Richter Recomposing Vivaldi’s 4 Seasons - One version contains a fifth section Vivaldi is not credited with.
- Star Trek film scores usually contain the theme refrain from the original series, so Alexander Courage is credited for the first movement.
I’ve managed to work around this so far with careful retagging - in the first instance I had to make Richters 5th season a distinct work, in the second I had to remove Alexander Courage.
Contiguous tracks on an album, where the work name matches and at least one of the composers is the same should be treated as movements under that work by the main composer. Album grouping should treat the work as a whole.
The “guest” composer should see a reduced view of the work that only contains the tracks they were involved with.
