[DONE] Movement Grouping Track Names
When grouping tracks under a Work, remove the Work Name text from the track name so the track name only contains the remaining text, the Movement Name: currently you can’t read the track names beyond the work name for a typical Classical Symphony
Serento does not add the Work title in the Movement title. It reads what the track name is and the track name contains the Work title.
So, I removed the Work title from the track title when tracks are grouped in Works.
Expect this fix in the next version.
Wonderful!
I can confirm this is done and very nice it is too
