[DONE] nhance Classical Work Grouping in Composer view
Under a Composer, the list of works could group available works more intelligently. As an example, under Holst at the moment I have 2 works showing:
  • The Planets
  • The Planets, op. 32
The work view already knows that The Planets is Holsts opus 32 as its shown under the name so, with that information, it should be able to tidy this up, merge these two together and temove the superfluous op. 32 from the work name.
There are other things to enhance in this area:
  • Always remove the opus info from the end of a work name here ( as its shown underneath)
  • Look for keywords when grouping and remove them too - in the example above “The Planets Suite” could be another common alias.
  • Advanced - Look up specific aliases or linguistic variances Debussy - Arabesques / Deux Arabesques for example.
This has been fixed in the next version.
Thank you for reporting it.
