I’ve had an issue with gapless behaviour on several devices. It’s an odd one and seems to happen when you either:
Start on one device then move to another
Pause for ages and come back later
I will send a log. I have experienced this on my Cambridge Stream Magic 6 and my Sony UHD BluRay player.
I have noticed that device detection can get hampered by my VPN and I have to switch it off when I refresh devices to pick up new ones and capabilities - this may be unrelated but could be a factor.
Thanks for the log. It shows the whole Bioscope session clearly.
Here is what happened on your Sony (BD-M1, the UBP-X800):
At 16:26 you started the 5.1 disc of Gentō (10 tracks, 24-bit/48 kHz FLAC) and moved it to the Sony before anything had played.
Serento loaded the first track on the Sony and started it. That was the only time during the whole album that Serento told the Sony to load and play a track.
After that, Serento gave the Sony the next track in advance every time. It did this between 2 min 45 s and 10 min 37 s before the end of the track that was playing.
The Sony made all 9 track changes itself, from the track it already had queued. Serento sent no play, stop or seek commands between tracks. There was no pause, seek or device change during the album.
So the gap you heard happened inside the Sony, while it was switching to a track it already had queued. Over UPnP/DLNA, Serento did everything a controller can do for gapless playback.
I also went back to the Sony log you sent in October, and it shows the same thing: the Sony made those transitions itself, with the next track already queued. At the time I linked that gap to the long pause. This log has no pause at all, so the pause wasn’t the cause on the Sony.
Other people have run into this on the same player. In this thread on the Audirvana forum, a UBP-X800M2 owner reports “a definitely audible break between tracks” over UPnP, even though the player says it supports gapless playback:
The only workaround mentioned there is foobar2000’s UPnP output. It decodes the music on the PC and sends the player one continuous stream.
The gaps on your Cambridge streamers in October were a different case. Those were Serento’s fault: the next track wasn’t queued after the first Play. That was fixed in 1.1.3.
To be sure about the Sony, could you tell me:
Which track change had the gap? Do you hear it at every change or only sometimes?
Does it also happen with stereo albums on the Sony, or only with 5.1?
Is the Sony connected to your Denon AVR over HDMI?
If you play the same album to the Sony from another app that queues the next track, is it gapless there?
If the other app has the same gap, it’s the Sony. If it plays without a gap, tell me which app it was and I’ll compare what it sends to the Sony with what Serento sends.
Other app wise there isn’t anything really. I got into Serento initially specifically for that player.
I haven’t noticed it before but I don’t often play both 5.1 and gapless so, not surprising there. I’m pretty sure it has worked fine before so isn’t a consistent issue.
Stereo wise most of the time sending it stereo content will crash the entire device.
The Sony is connected via HDMI, yes - sadly it doesn’t have a multi analogue out and the Denon doesn’t play Multichannel over DLNA which is… crazy but heigh ho.
