Ignore “The” for identification in places / Orchestra Identification
I’m not sure what the best scope of this would be, but the immediate area where I am picking up on it is in Orchestras, where, for example, “Royal Philharmonic Orchestra” and “The Royal Philharmonic Orchestra” show as 2 different Orchestras.
In fact, orchestras are a weird breed that often have many aliases, so mischievous so that Musicbrainz has a whole section for it.
For example, “Antwerp Symphony Orchestra” is the same as the “Royal Flemish Orchestra”. Then you get into the joys of language, which is a prevalent issue in Classical identification, both with Orchestras and Works.
“Berlin Philharmonic”, “Berlin Philharmonic Orchestra” and “Berlin Philharmoniker” are all the same - personally I try to keep orchestra and track names language native where possible, certainly for the bigger Orchestras like the Berlin Philharmoniker, but a lot will depend on what information I have available. Tagging can be a linguistic inconsistency nightmare.
As with automatically removing ‘The’ from an artist name I personally do not think this should be done. Some people may like an orchestra name including ‘The’ others don’t.
I completely agree that “tagging can be a Linguistic inconsistency nightmare”, but I think getting consistency should be up to the user, not an app. If on day 1 the user chose to have orchestra names without ‘The’ but their latest rip puts it in it’s so easy to change.
Every couple of years I export my library to a spreadsheet and using functions like ‘Remove Duplicates’ check for naming inconsistences. It’s still a lot of eyeballing the data but it’s quite satisfying rectifying mistakes. Perhaps I just need to get a life :thinking: .
That is a tough problem to solve and it cannot simply be solved without involving the server side to be able to find all the variances of one orchestra. I will think about a solution for this.
Regarding the “The” problem, I will add a solution in the 1.1.3 version. The user will be able to turn off the word “The” from:
  1. Sorting.
  2. Artist name detection and this includes orchestras.
  3. Any other place I will find after researching all the surfaces where artist names are displayed.
Users will be able to set if they want this to be synced across devices or not.
Any suggestions are appreciated.
@Gaz - I’m with you on the Artist thing, hence I think it should be a user choice thing, but this is a different issue to alphabetic ordering etc.
In this case, we want the app to not care whether “The” is present or not for an Orchestra name and know they are the same Orchestra - Whether they would then display as “The XXX Orchestra” or “XXX Orchestra” would then depend on the majority of your tagged info, but would ensure that they are still picked up as being the same single entity regardless and make the identification more robust.
Band name variances could appear the same way - Here’s a real world example: You have 15 albums by “Pink Floyd”. Their first album was released under the printed name “The Pink Floyd”. In an ideal world we’d leave the tags on their first album as “The Pink Floyd” but the app would recognise that these are the same band and merge everything under a single name “Pink Floyd” (because there are more albums under “Pink Floyd” than “The Pink Floyd”). Currently we workaround this by changing the band name on their first album to match what follows.
I think this stands out with classical stuff even more because tagging it is such a huge amount of work to get right - fixing it up in a straight Artist / Album / AlbumArtist model is much simpler.
@tiefling I’m absolutely in agreement with you, using your Pink Floyd example, that this would be a great thing for Serento to do. I guess I’ve just got used to apps that just present what is in the tags, i.e. what you’ve entered is what you get. Using your Pink Floyd example again, I would have just made sure I entered ‘Pink Floyd’ for every album. Technically that may not have been correct but at least it kept an artists albums together. The other reason I did this is so an artists albums are grouped together in Windows folders. My folder naming format is “Pink Floyd - Wish you were here”, “Pink Floyd - Dark side of the moon”, etc, etc.
Perhaps Serento is spoiling us with what it can do, which is no bad thing :grinning_face:
Indeed - I’m in a great position at the moment to identify stuff like this as I’ve traditionally been really solid with my tags, but as I rework things for expanding my genre base (because Serento is amazing) it also reveals quirky little things that lead you down angles of “Oh, but if it covered this angle…”
It’s a tricky balance between optimising the intelligence of what the app can do for the user while also allowing personal direction and preference.
This has been implemented in the upcoming 1.1.3 version.
