Missing Images in Orchestra Section
I have put images in my indexArtwork folder for Orchestra but a lot of them are not showing up.
I have realised that the way MinimServer exposes what appears in the Orchestra section in Serento isn’t always in the Orchestra folder.
I’ve covered all bases and moved everything into a single Artist folder and Symlinked to it from Orchestra, Choir and Ensemble - will see how it goes
Hi @tiefling,
You should place everything in indexArtwork/Artist and it will match any type of entity based on the name, including Orchestras. Don’t create a folder for each type of artist or group.
After moving the images in indexArtwork/Artist run a sync.
That works, Symlinking lets MinimServer surface the images everywhere.
