Movement Readability in Works View vs Album View
When you view tracks in an album that are grouped by a Work the Work name is shown as the group and the Movement name with the Work name removed underneath which is nice.
In Work view this doesn’t happen leading to a list of Movements where the only visible text is the first part of the Work name before space runs out.
I sent a log for another bug, but I’ve recently added / re-tagged several classical Symphonies (Mozart, Tchaikovsky, Sibelius) and a Ravel album that all show this effect to some degree.
I’ve done a lot more investigating here with some test data and it seems that the following happens:
In album view the grouping title is the Work - The Movement is then used in place of the track name where a Movement name is present.
In work view the track title is always used and the Movement tag is ignored.
In all cases, where the track title is used, the Work name is removed from the beginning (nice), but if the work name and title prefix don’t perfectly match you end up with a very long title (the work may contain an opus suffix which is not in the title as a common example).
The main issue seems to be that the work view should behave like the album view and always use the movement tag if one is present. The app could start to try and get clever with text removal for certain expressions so things like “op. XX” could be ignored, but that would probably be a lot of load for bot much gain.
This has been fixed in the next version.
Thank you for reporting it.
