Have tried different ways and can only add one entry. Certainly different then Roon and Qobuz.
Hi @JKND68!
There isn’t any limitation on adding tracks to a playlist. You can have a playlist as big as you want. Your entire library can fit in a playlist if you so desire.
Can you provide more details?
- Have you synced with your server? What server are you using? How much music do you have on the server?
- You can add one entry at a time by pressing … on a track or album and selecting add to playlist. Or long press on any item and start selecting multiple items and then in the multi select bar at the bottom press the … button and select add to playlist.
Let me know and I’ll try to help you further.
Hi Lorin,
My server is a MacMini M2 Pro 16Gb, I have about 18,000 Albums, many not well organized.i will sync with server tonight. Will try tomorrow to add playlists. I have more to learn about your wonderful Ap. My music sounds great!
Thanks,
Jeff
