Tracks not being deleted from queue
It seems that when I’ve deleted tracks from the queue they are not being properly deleted. Here’s the scenario:-
I have a CD with 10 tracks. I just want to play track 5 but accidentally press ‘Add to queue from here’ instead of ‘Add to queue’. So, I go to the queue and delete tracks 6 - 10. When the queue gets to track 5 it plays but then so do the tracks I’ve deleted. If I look at the queue it shows it’s playing track 5, over and over again, when it’s actually playing the deleted tracks.
I think this has happened before but I assumed I didn’t delete the tracks properly. Today I know I deleted the tracks but they still played.
Thanks @Gaz , I found it.
When the queue is edited while Serento is still sending the previous change to the streamer (for example deleting tracks right after “Add to queue from here”), the later edits were dropped instead of being sent afterwards, so the streamer kept the tracks you had deleted. In the next update a queue edit is never dropped: if the streamer is busy, it is sent as soon as the previous change finishes. If it happens again after the update, a log file would help.
