BUG: DSD over PCM
On my 2 Cambridge Audio streamers I have different capabilities.
One accepts DSD64 the other only PCM.
To support this I have MinimStreamer set up to convert DSD above 64 to 24/176 or 24/88 PCM. This works fine through the native apps, but Serento tries to force DSD over PCM which does not work and I get nothing.
Hi @tiefling.
This is weird. Do you think you can send me some log files that capture the moment you play these files? It would help a lot.
Thanks,
I was able to reproduce the issue. And thanks to your bug report I discovered 2 new issues:
  1. The number of albums during a sync grows because of the way MinimServer publishes the track resources.
  2. The sync could restart mid sync.
I have fixed all these issues. Serento now asks for the resources on playback request and no longer reads the resource saved during sync for each track.
Thank you for the bug report,
This seems to be part fixed.
My DSD64 and DSD256 test material is now playing as PCM 24/88 to my Stream Magic 6, which is perfect.
My DSD256 test material does not play on my CXN v2, which supports DSD up to 64. In that scenario, you want to PCM convert as well (oh to be able to downconvert DSD without a PCM intermediary). Log sent.
There may be a UI bug here though. In testing I tested the DSD64 on the CXN v2 and it plays fine and the device shows DSD64 but Serento shows DSD over PCM rather than BIT-PERFECT. In contrast, when playing to the Stream Magic 6, Serento shows HI-RES 24/88 and BIT-PERFECT when it should probably be showing the second item as DSD OVER PCM. Second log sent.
Hi @tiefling,
Thanks for the log.
Stream Magic 6.
This one is working as intended. The Stream Magic 6 doesn’t accept DSD, so Serento picks the PCM 24/88 version that MinimStreamer publishes alongside each DSD file, and sends it unchanged. What reaches the streamer is real PCM, produced by MinimServer’s conversion. DSD over PCM (DoP) is something different: the DSD bits packed unchanged inside PCM frames, which the DAC unpacks back into DSD. So HI-RES 24/88 is exactly what the Stream Magic receives, and BIT-PERFECT means Serento passes MinimServer’s stream through untouched.
DSD64 on the CXN v2.
You’re right, that label is wrong. Serento sends the DSF file to the CXN v2 untouched, so it should say BIT-PERFECT. The iPhone version labels every DSD stream sent to a streamer as DSD over PCM without checking, while the iPad and Mac versions already show BIT-PERFECT. I’ll fix it in the next update.
DSD256 on the CXN v2.
Your log shows what happens. For that track MinimServer offers two versions: the original DSD256 file and a PCM 24/88 version. The CXN v2 tells control points that it plays DSF files, but not up to which rate, so Serento sends the original. The CXN v2 refuses it, and after retrying Serento shows the error. The PCM version would have played. I’ll change this: when a streamer refuses a DSD file and the server offers a version the streamer accepts, Serento will switch to it and remember the limit for that streamer, so later DSD256 tracks go straight to PCM.
Thanks again,
