BUG: Grouping Across Different Recordings of a Work
This is an edge case, but here we have a disc containing 2 versions of “Hergest Ridge” so the work is the same, but the 4 grouped tracks represent 2 different instances (the latter ones need an extra suffix in the Movement Name so that’s a tagging issue) but the app issue is that the work grouping should wrap Parts One and Two only and then again for the second instances if Parts One and Two.
While the work IS the same, the movementtotal field is 2, and Part 1 and 2 have movementnumber fields on 1 and 2 respectively, so the grouping should restart.
You could easily have this in a Classical release too with multiple recordings of the same work.
Hi @tiefling,
I see where the issue is. I will fix this in the next version.
This has been fixed in the next version.
Thank you for reporting it.
