Where an album has multiple Genres on different tracks, the app seems to pick one track at random to use as the genres for the album.
In my test I had an 18 track album where most of the tracks had the genres: Contemporary Classical; Modern Classical; Neo-Classical; Soundtrack
I then had 4 tracks that differed - 1 with World; Africa; Soundtrack, 1 with Turntablism; Soundtrack (I forget the others - but link: Verifying your browser)
The album data returned the genres only for Track 14 (World; Africa; Soundtrack)
This is an unusual edge case so I set the whole album to be the same as a workaround for now.
Hi.
Serento displays the genre set in the Album genre tag, not the track genre. Can you check the metadata for the album and let me know if it’s the value you saw in the app?
Thanks.
I don’t have anything with an Album Genre tag. This one’s confused me somewhat. Is this a DLNA thing, because file wise it’s not unless I create a random custom tag.
The genres were showing as expected under “Genre” in MinimServer with the tracks under each genre…
I think I’ve figured this out!
On MinimServer, if you have an album with tracks that have different Genres the Genre index takes you to the files that are in the album for that genre with a “Complete Album >>” link back. Serento was showing “World; Africa; Soundtrack” as the album genres. If the Genre index is parsed alphabetically then the first genre that would be hit would be “Africa” - If it then reads the content there for other genres then you would get… “World; Africa; Soundtrack” because unless you navigate down to “Complete Album >>” you wouldn’t know any better.
I’m going to set a random track on an album with a genre of “Aardvark;Dubstep” and see what happens to it to test.
You are correct. I check and indeed Serento takes the genre from the first track in alphabetical order. I will fix this and add up all the track genres.
I spent 2 years as a Dev Lead on Nokia Music’s Testing Framework team - Now I just have a knack to break everything
Where were you when the beta testing was going on?
Building a massive engine to run the 24 hours of regression tests. Scale was a huge problem for years.
One question! If most tracks have classical and one track has something else, would it make sense for the album to have classical as genre? I was thinking to measure the weight of every track genre and display the most dominant genres.
Yes - I have a few like that where the album is primarily either Classical or some modern Classical subgenre then you have a weird add-on.
The case above is the Iris Score by A Winged Victory for the Sullen - Primarily modern classical with some weird extras from the film.
Weight measuring would make sense - perhaps ignore any genres completely from an album perspective that don’t occur more than once for a start.
This has been fixed in the next update.
Tracks display their genres, albums display genres based on genre weight and custom genres and genre tag split are taken into account when displaying genres.
The radio function now uses the track genre to build the queue which is going to make the radio function a lot more accurate.
Thank you for the bug report.
