BUG (Minor): Sibelius appearing as an ENSEMBLE / ORCHESTRA
The app is adding “Sibelius” as an ENSEMBLE for 2 London Symphony Orchestra symphonies of his work. I’ve reviewed the tags in detail and even added a specific Orchestra tag but it’s still doing the same thing.
I found the cause for this (sort of).
When getting classical tags (Picard + Classical plugin), the Composer is often added as the first Album Artist. When the composer name added here is just the composer Surname AND the Artists field contains the full Composer name the surname only version seems to be interpreted as being the Orchestra.
This is not consistent - The combination of Sibelius / Jean Sibelius and Mozart / Wolfgang Amadeus Mozart triggers the issue, but Tchaikovsky / Piotr Illyavich Tchaikovsky does not (for an example)
The Orchestra and Band field don’t seem to be used directly.
I have worked around this by using the full composer name in both fields and the orchestra is then determined correctly, so the Composer no longer appears as an ensemble.
This has been fixed in the next version.
Thank you for reporting it.
