Where there are several tracks that form part of the same work, in CLASSICAL works view, they are no longer both appearing.
In Mike Oldfields Music of the Spheres, for example there are 2 works which have primary part “Harbinger” and a secondary part “Harbinger (reprise)”. The work view now shows the reprise but the main track has completely disappeared.
There are other examples of this - I assume it’s related to changes around the movement numbers as these aren’t works that have multiple parts they are effectively variations on the same work - they aren’t a grouping but different versions of the same work.
I have more info on this - I’ve been tag digging and this album has some very specific criteria:
Most of the tracks on the album have both a Work and Movement that match the Track name, as I’ve kept the tracks as separate works.
The exceptions are the tracks affected by this issue:
Both of these have themselves as “Work” but had no “Movement” tag.
The tracks:
- Harbinger (reprise)
- On My Heart (reprise)
used the main track for the “Work” tag but they ALSO had Movement tags which the main track did not.
I’m about to re-sync, but I suspect that this issue may go away by adding a “Movement” tag where it’s missing.
I suspect this is NOT a bug and works as intended if my theory is correct, as excluding tracks by ignoring ones from the Classical view that do not have a Movement tag is a nice way to handle it (I have a nasty half classical / half rock soundtrack album for “The Young Pope” which is a wonderful test case for this)
