This is a series of posts I’m putting up to support people using MusicBrainz Picard with Serento. It’s scripting functionality is a little daunting to start with but is incredibly powerful. You can create scripts which run either when you drop in an album to tag or to run manually. I will update these posts as my own scripts evolve.
Feel free to use these as a basis and make your own, or post any questions and I’ll be happy to help where and when I can!
You can create and edit scripts under OPTIONS > Scripting
If you tick the box next to the script the script will run automatically.
If you do not tick the box you select the files you want to run the script on, right click and go to RUN SCRIPTS > (name)
These scripts are mostly intended to be used alongside the excellent Classical Extras Plugin.
Ensure Classical Fields
I always run this first on all my classical files to make sure I have all the key fields - populating missing bits where I can
$set(__temp_ensemble,)
$set(__temp_ensemble_sort,)
$set(__temp_choir,)
$set(__temp_choir_sort,)
$if(%performer:ensemble%,$set(__temp_ensemble,%performer:ensemble%))
$if(%performer:orchestra%,$set(__temp_ensemble,%performer:orchestra%))
$if(%band%,$set(__temp_ensemble,%band%))
$if(%ensemble%,$set(__temp_ensemble,%ensemble%))
$if(%orchestra%,$set(__temp_ensemble,%orchestra%))
$if(%band_sort%,$set(__temp_ensemble_sort,%band_sort%))
$if(%ensemble_sort%,$set(__temp_ensemble_sort,%ensemble_sort%))
$if(%orchestra_sort%,$set(__temp_ensemble_sort,%orchestra_sort%))
$if(%performer:choir%,$set(__temp_choir,%performer:choir%))
$if(%choir%,$set(__temp_choir,%choir%))
$if(%choir_sort%,$set(__temp_choir_sort,%choir_sort%))
$if($eq(%__temp_ensemble_sort%,),$set(__temp_ensemble_sort,%__temp_ensemble%))
$if($eq(%__temp_choir_sort%,),$set(__temp_choir_sort,%__temp_choir%))
$set(band,%__temp_ensemble%)
$set(band_sort,%__temp_ensemble_sort%)
$set(ensemble,%__temp_ensemble%)
$set(ensemble_sort,%__temp_ensemble_sort%)
$set(orchestra,%__temp_ensemble%)
$set(orchestra_sort,%__temp_ensemble_sort%)
$if($eq(%composer%,),$setmulti(composer,%artists%))
$if($eq(%composer%,),$setmulti(composer,%artist%))
$if($eq(%composersort%,),$setmulti(composersort,%artists_sort%))
$if($eq(%composersort%,),$setmulti(composersort,%artistsort%))
$unset(__temp_ensemble)
$unset(__temp_ensemble_sort)
Create a Whole Album Work
This creates a classical work across a whole album - useful for complete pieces like a classical film score or a good starting point to then hand edit other pieces.
$set(work,%album%)
$set(__temp_movement,%title%)
$if($eq(0,$find(%title%,%album%)),$set(__temp_movement,$replace(%title%,%album%,)))
$set(movement,%__temp_movement%)
$set(movementnumber,%_absolutetracknumber%)
$set(movementtotal,%_totalalbumtracks%)
Create Single Track Works
This creates a work / movement combination based on the track itself - Another good starting point to then manually tweak from - good time saver.
Basic version
$set(work,%title%)
$set(movement,%title%)
$delete(movementnumber)
$delete(movementtotal)
Complex version
$set(__temp_work,$if(%work%,%work%,%title%))
# List in reverse priority order so last takes precedence
$setmulti(__test_sep,: )
$setmulti(__test_sep, - )
$foreach(%__test_sep%,
$set(__idx,$find(%title%,%_loop_value%))
$if(%__idx%,
$set(__temp_work,$substr(%title%,0,%__idx%))
$set(__temp_movement,$replace($substr(%title%,%__idx%),%__test_sep%,))
$set(work,%__temp_work%)
$set(__temp_work,)
$set(__temp_movement,)
$set(__temp_sep,)
Create Disc Based Works
This creates a work / movement combination based on the disc number - It’s a hybrid between whole album and track based.
$set(__temp_work,$if(%work%,%work%,$if(%discsubtitle%,%discsubtitle%,$if(%discnumber%,%album% - Part %discnumber%,%album%))))
$if(%__idx%,
$set(movementnumber,%tracknumber%)
$set(movementtotal,%totaltracks%)
$set(__temp_work,)
$set(__test_sep,)
Create clean Movement Names (Ballet)
I made this for dealing with some Ballets
$set(__temp_work,%work%)
$set(__temp_work,$rreplace(%__temp_work%,\, op\(.*\),))
$set(__temp_work,$replace(%work%,The Sleeping Beauty,Sleeping Beauty))
$set(__temp_movement,$replace(%__temp_movement%,%__temp_work%: ,))
$set(__temp_act_title,$rsearch(%__temp_movement%,"\(.*\)")
$if(%__temp_act_title%,
$set(__temp_act_title, "%__temp_act_title%" :),
$set(__temp_movement,$rreplace(%__temp_movement%,Prologue\(\\.|:\),Prologue:))
$set(__temp_movement,$rreplace(%__temp_movement%,Act One\(\\.|:\),Act I:))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Two\(\\.|:\),Act II:))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Three\(\\.|:\),Act III:))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Four\(\\.|:\),Act IV:))
$set(__temp_movement,$rreplace(%__temp_movement%,Act One,Act I))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Two,Act II))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Three,Act III))
$set(__temp_movement,$rreplace(%__temp_movement%,Act Four,Act IV))
$unset(__temp_movement)
$unset(__temp_work)
$unset(__temp_act_title)
Flatten Multi-Level Works
This ensures that any Classical Work data added is flattened rather than layered.
$if(%top_work%,$set(work,%top_work%))
# Lose Top Work / Style
$delete(style)
$delete(top_work)
# Clean Name
$set(title,$replace($if(%title%,%title%,Unknown), - ,: ))
Stripping Classical Fields
If you want to make all the custom stuff from the Classical Extras Plugin go away (you forgot to turn it off on a Rock album for example) this is VERY handy:
$set(__temp_choir,)
