Much like the Format filter - Allow for a channel filter. Most obvious use cases are filtering in / out 5.1/4.0 or Stereo based on the player you have available at the time.
If the filter cut inside albums that contained multiple formats without too much added complexity or processing overhead that would be really nice, but at album level would be a good start.
I have a lot of albums which have multiple discs for Stereo and 5.1 mixes, for example - I also have them set up as distinct versions sometimes as well. I have a few albums that are purely 5.1/4.0/5.0.
From a UX perspective, I often approach listening with either Stereo or Surround in mind over 75% of the time, either because the equipment is limited or because I have quiet time for the dedicated listening surround usually demands.
