Hi,
I’ve been using Serento almost from day 1 and generally I’m really happy using the app. The layout is good and the the various ways of selecting and playing music is great. I however have a couple of issues with the app…
Genres - I have 30 different genres configured across my albums, which has taken some time to get them just how i like them to find the music I want. I’m a bit concerned that Serento seems to mash those 30 genres down to 8.
You said on the Audiogon forum “Serento now reports exactly the genres your server reports. If your server says you have 88 genres, you get 88 genres, with the names it uses.”. Is this still the plan? If so is there any timescale to implement it?
I have found that I can use the Folder view to display all my genres, but even that has an issue as it seems to make one genre an album. Even stranger is it takes the genre picture in the Minimserver indexArtwork folder for that one genre.
Recently Added - The app doesn’t show recently added albums. On the home screen, where the title is ‘Recently Added’ most of the albums it shows haven’t been added in the past couple of years.
In Album view I assume that the little up/down arrows at the top can be used for sorting albums. If I sort via Recently Added it doesn’t show any albums that I have recently added to the library. Actually, the same applies to Recently Played and Most Played.
I’ve used my old Control app, in folder view, and Genre, Recently Added and Recently Played all display as I would expect. I assume this is using Minimservers algorithm and my tags, and Minimserver are configured correctly.
I hope these few issues can be rectified as I really do like the app.
