Music “pauses” between tracks
I’ve had an issue a few times now where when a track has finished playing it seems like the music has been paused for a minute and then continues to the next track. If I look at the queue it appears the ended track is still playing, although it’s not. If I go back and replay the track it continues playing to the next track as normal.
I can seem no common reason why this happens, it occurs on different albums and seems completely random. It doesn’t happen very often, I’ve not noticed it more than once in the same day.
Hi Gaz,
This sounds like the same issue @tiefling had. Are you on the latest version, 1.1.3? There is a fix in the latest update for this, but yours might be a different issue and it depends on the streamer. Can you turn on the logs and next time it happens send me those logs?
Hi Lorin,
Actually I wasn’t on the latest version :roll_eyes: . I’ve updated now and hopefully that’s fixed the problem. I will report back if it happens again.
Thanks
Gaz
Don’t worry about it. I haven’t announced the latest version because the Apple TV app is still in review at Apple and I wanted to announce the new version when the Apple TV app is approved.
Let me know if it still happens.
Hi Lorin,
I had the problem again today, although slightly different. Previously when the music stopped the now playing bars would show the last track as still playing, although it had ended. Today when the music stopped the now playing bars went to a track way back in the queue, but didn’t show the track as playing, the bars just sat there.
I replayed the track where the music had stopped and everything carried on as normal. Sorry, while I was trying to work out what was going on I forgot to start logging.
I am now running 1.1.3.
Regards
Gaz
Sorry for all the playback troubles you are having. Please turn on the logging and leave it on. Next time it happens send me the logs and please write your name and mention “playback issue” in the details and I’ll take care of it.
Thank you!
