Playlist problems across MacOS and iOS
I’ve got a couple of playlist problems happening. They’re slightly different between MacOS and iOS.
On the desktop, out of my 40+ playlists, certain ones will crash the program, every time.
On iOS, on the main playlist list, the right amount of tracks for each pl is displayed correctly. On going into that playlist, the number will decrease to, what seems to me, a random amount. So, a 15 track playlist will then say it only contains 6, even though I can see all 15 displayed in the list. On playing it, it will skip some tracks, only playing 6 out of the 15.
I’ve sent logs for both instances.
Hi Wil,
Thank you for the report and the logs.
What causes the number discrepancy
Serento matches every entry of a playlist to a track in your library. The list on the playlist screen and the track count with the Play button used two different ways of doing that, and they did not always agree.
Since some of your tracks were added to playlists, Plex has updated their details. Tracks from compilations that used to show “Various Artists” now show the real artist, and a few names changed slightly, for example Jean‐Michel Jarre written differently. The list still recognised these tracks; the count and the Play button did not. In Paperlate and Gorf the list showed 27 tracks while the header said 21, and Play played only those 21.
The fix
  • A track is now recognised by its file on your server, so a change to its details in Plex no longer drops it from the count or from playback. This applies everywhere a playlist is played, on all your devices.
  • The track count and the Play, Shuffle, Play Next, Add to Queue and Download buttons now always use exactly the tracks the list shows.
The count, the list and playback will always agree. Only tracks that really are no longer in your library are left out, and they appear as greyed-out rows at the end of the list, so you can see which ones they are and remove or replace them.
The fix will be in the next update.
What causes the crash
When a playlist contains a track Serento can no longer find in your library, it shows that track as a greyed-out row at the end of the list. On the Mac, a small piece of code prepares the album covers of the rows just below the ones on screen. When the whole playlist fits on the screen, that code counted the greyed-out row as a real track and asked for a position that does not exist, and that stopped the app.
That is why it is always the same playlists. In your log, three of them crash every time you open them, and each has exactly one track that is no longer in your library:
  • Petite & Protruding: She’s Gone (Daryl Hall & John Oates, The Singles)
  • 2 15p 99s, please: B.J. and the Bear (Television’s Greatest Hits, Volume 6: Remote Control)
  • 5000 On Cities: Take a Load Off Your Feet (Beyond the Pale Horizon)
Playlists where every track is found open normally. iPhone and iPad use different code for this and are not affected.
The fix
The cover preparation now looks only at real tracks, so a greyed-out row can no longer stop the app. The fix will be in the next update.
Until then
You can open these playlists on your Mac again by removing the greyed-out track from each of them on your iPhone: open the playlist, tap ⋯ next to the greyed-out track and choose Remove from Playlist. The change syncs to your Mac.
Thanks again for taking the time to send the logs.
Thanks Lorin,
I really appreciate the time you take to explain all of this.
Wil
