This is a series of posts I’m putting up to support people using MusicBrainz Picard with Serento. It’s scripting functionality is a little daunting to start with but is incredibly powerful. You can create scripts which run either when you drop in an album to tag or to run manually. I will update these posts as my own scripts evolve.
Feel free to use these as a basis and make your own, or post any questions and I’ll be happy to help where and when I can!
You can create and edit scripts under OPTIONS > Scripting
If you tick the box next to the script the script will run automatically.
If you do not tick the box you select the files you want to run the script on, right click and go to RUN SCRIPTS > (name)
This script will remove common garbage / noise tags from your files - this can be very dependent on your own needs so use this as a starter and adjust for your own requirements.
$delete(contentgroup)
$delete(accurateripcount)
$delete(accurateripcountalloffsets)
$delete(accurateripcountallwithoffset)
$delete(accurateripcrc)
$delete(accurateripdiscid)
$delete(accurateripid)
$delete(accurateripoffset)
$delete(accurateriptotal)
$delete(albumrating)
$delete(album rating)
$delete(album_rating)
$delete(albumdynamicrange)
$delete(album dynamic range)
$delete(album_dynamic_range)
$delete(cdtoc)
$delete(ctdbdiscconfidence)
$delete(display artist)
$delete(display_artist)
$delete(DISPLAY ARTIST)
$delete(DISPLAY_ARTIST)
$delete(display composer)
$delete(display_composer)
$delete(DISPLAY COMPOSER)
$delete(DISPLAY_COMPOSER)
$delete(dynamic range)
$delete(dynamic_range)
$delete(Encoded By)
$delete(encoded by)
$delete(encoded_by)
$delete(encoder)
$delete(Encoder)
$delete(Encoder Settings)
$delete(encoder_settings)
$delete(encoder settings)
$delete(encodersettings)
$delete(Encoding Params)
$delete(encoding params)
$delete(encoding_params)
$delete(Encoded By)
$delete(encoded_by)
$delete(ieng)
$delete(isft)
$delete(itunes_cddb)
$delete(itunes_cddb_1)
$delete(itunes_cddb_tracknumber)
$delete(itunesadvisory)
$delete(labelno)
$delete(rip date)
$delete(Rip date)
$delete(Rip Date)
$delete(rip_date)
$delete(ripping tool)
$delete(Ripping tool)
$delete(Ripping Tool)
$delete(ripping_tool)
$delete(Source)
$delete(source)
$delete(Comment [ID3v1 Comment])
$delete(comment [id3v1 comment])
$if($eq(%tempo%,00000 BPM),$delete(tempo))
$if($eq(%grouping%,Digital Only),$delete(grouping))
$if($eq(%grouping%,CD),$delete(grouping))
$if($eq(%grouping%,Vinyl),$delete(grouping))
$if($eq(%catalognumber%,[none]),$delete(catalognumber))
$if($eq(%totaldiscs%,1),$delete(discnumber))
$if($eq(%totaldiscs%,1),$delete(totaldiscs))
$unset(length)
