Show All Albums as a default option
Love the app so far - I have a mixed estate of streamers so just what I have been looking for. One minor thing for me is that when selecting an artist the app just shows the first 2 albums on the iPhone screen or first 4 on iPad mini. From a personal perspective 99/100 times I want to scroll through my albums for that artist and would appreciate the ability to set the app to default to this when selecting the Artist. Similarly, it’s my music library - I know what I like so I don’t need to see the Popular Tracks section so the ability to turn this off would be great.
Hi @MikeGreenwood!
Thanks for the suggestion!
This has been implemented in version 1.1.8 which is at Apple for review. Once the update is live go into Settings - Artists Settings - Artist Page Albums - Turn on Show all albums.
Expect it tonight or tomorrow.
Hi @lorin.bute
I really like how the artist view now shows all the albums. Could the same option be applied to the Genre view?
Gaz
@lorin.bute as an addendum to this, can I suggest that where a section is affected by “Show All” being an active setting, that the “Show All” link is replaced by a Collapse / Show arrow, so you can collapse the albums quickly to get to the sections underneath.
@Gaz / @MikeGreenwood - Would this be better represented with a “Primary Music Type” for each view? You could then have something like this:
  • Show All Primary Media - Primary Media:
    • Artist: OFF / Albums / Tracks / EPs & Singles
    • Genre: OFF / Tracks / Albums / Subgenres
    • Others? - Can’t see it making sense for Tracks or Playlists
I think this might be a bit tricky on the Genre view as there’s a lot of elements to it already.
For my preferences, I’d put the Subgenres at the top of the Genre section (Perhaps that’s a separate thing?), and I’d probably go to Tracks first. Showing all Albums for an Artist I’d almost certainly turn on though.
NOTE: This totally needs a better name than “Primary Media Type” - I’m not feeling very word inventive today! :slight_smile:
Replace show all with collapse suggestion is good, other detail not particularly important for me personally but could see others using it
I Agee with @MikeGreenwood , the collapse idea sounds good but I also probably wouldn’t make use of the other options, but I guess it doesn’t do any harm to have them.
@Gaz - I think it depends on what makes for the best compromise of what to go where and keeping any config as simple and lightweight as possible. Adding a ton of options is probably not the best way forward - it’s been a long day! Excuse my frazzled head.
I’d like to be able to have all the albums open in artist view, but in genre view that’s more likely to be a very long list for me so if it was a “Show All Albums” ON / OFF option for each of those views that would be great. If it was one setting across all, I’d probably leave it off so my Genre view doesn’t get album crowded.
@tiefling Sorry for the confusion, I never intended to imply that there should be one ‘show all albums’ setting that covers all views. There should be separate on/off settings for Artist (already done) and Genre views.
As I just have flat genres I hadn’t taken into account how it would handle systems , like yours, that have sub-genres. If ‘show all albums’ was on I can see that it might show an awful lot of albums under a single genre. If it was left off I guess you would get the same view as now.
Hello everyone,
I completely understand the need to have all the albums listed in genres or in other lists.
Unfortunately it cannot be a universal rule. Everyone has a different need and library size.
The genre view is already heavy in data. Listing all the albums would make it even more cluttered, something I prefer to not do. Also, when pressing View All you get a few important functions you don’t get in the Genre view: the chrome of buttons and the play button. Once you see the full list you get access to filtering, pick for me and playback controls. When I started this application I promised myself that these options should be available everywhere to make the user experience as best as possible. And a lot of beta testers appreciated this which further cemented the fact that the chrome needs to be there.
A list of albums in the genre view would be less of a problem for someone with a small library and a very big problem for someone with a large library. An option to show all the albums would make sense. But the View All button stays because it’s the only thing taking you to the chrome I mentioned earlier.
I will investigate solutions for this and I’ll let you know.
