Tagging Genres [PART 1]
This is a series of posts I’m putting up to support people using MusicBrainz Picard with Serento. It’s scripting functionality is a little daunting to start with but is incredibly powerful. You can create scripts which run either when you drop in an album to tag or to run manually. I will update these posts as my own scripts evolve.
Feel free to use these as a basis and make your own, or post any questions and I’ll be happy to help where and when I can!
You can create and edit scripts under OPTIONS > Scripting
If you tick the box next to the script the script will run automatically.
If you do not tick the box you select the files you want to run the script on, right click and go to RUN SCRIPTS > (name)
This script will set genres and subgenres in a way that better suits the Serento taxonomy. This script is in 2 posts as it’s too long to post in one.
Current Status: Works great up to 1980s - More work pending on later genres.
$noop(Can use get_original here but - Needs Picard 3)
$set(__temp_genre,$lower(%genre%))
$set(genre,)
# Picard naturally splits on semicolons when you setmulti
# So if we set a value containing "; " it becomes separate entries
$setmulti(__saved_genre,%__temp_genre%)
$noop(Can use copymerge to merge original here but - Needs Picard 3)
# Decade Genres
$if($or($inmulti(%__saved_genre%,1960s),$in(%_dirname%,1960s)),
    $setmulti(genre,%genre%; 1960s))
$if($or($inmulti(%__saved_genre%,1970s),$in(%_dirname%,1970s)),
    $setmulti(genre,%genre%; 1970s))
$if($or($inmulti(%__saved_genre%,1980s),$in(%_dirname%,1980s)),
    $setmulti(genre,%genre%; 1980s))
$if($or($inmulti(%__saved_genre%,1990s),$in(%_dirname%,1990s)),
    $setmulti(genre,%genre%; 1990s))
$if($or($inmulti(%__saved_genre%,2000s),$in(%_dirname%,2000s)),
    $setmulti(genre,%genre%; 2000s))
$if($or($inmulti(%__saved_genre%,2010+ post digital era),$in(%_dirname%,2010+ Post-Digital Era)),
    $setmulti(genre,%genre%; 2010+ Post Digital Era))
$if($or($inmulti(%__saved_genre%,2010+ post digital era pop),$in(%_dirname%,2010+ Post-Digital Era Pop)),
# CLASSICAL GENRES
$if($or($inmulti(%__saved_genre%,classical),$inmulti(%__saved_genre%,ballet),$inmulti(%__saved_genre%,baroque),$inmulti(%__saved_genre%,chamber music),$inmulti(%__saved_genre%,choral),$inmulti(%__saved_genre%,choral symphony),$inmulti(%__saved_genre%,cinematic classical),$inmulti(%__saved_genre%,classical period),$inmulti(%__saved_genre%,concerto),$inmulti(%__saved_genre%,contemporary classical),$inmulti(%__saved_genre%,cello concerto),$inmulti(%__saved_genre%,fantasia),$inmulti(%__saved_genre%,gregorian chant),$inmulti(%__saved_genre%,impressionism),$inmulti(%__saved_genre%,medieval),$inmulti(%__saved_genre%,minimalism),$inmulti(%__saved_genre%,modern classical),$inmulti(%__saved_genre%,modernism),$inmulti(%__saved_genre%,neo-classical),$inmulti(%__saved_genre%,neoclassical),$inmulti(%__saved_genre%,neoclassicism),$inmulti(%__saved_genre%,opera),$inmulti(%__saved_genre%,song),$inmulti(%__saved_genre%,post-classical),$inmulti(%__saved_genre%,post-minimalism),$inmulti(%__saved_genre%,postminimalism),$inmulti(%__saved_genre%,renaissance),$inmulti(%__saved_genre%,requiem),$inmulti(%__saved_genre%,rhapsody),$inmulti(%__saved_genre%,romantic classical),$inmulti(%__saved_genre%,romantic),$inmulti(%__saved_genre%,sacred vocal music),$inmulti(%__saved_genre%,score),$inmulti(%__saved_genre%,film score),$inmulti(%__saved_genre%,string quartet),$inmulti(%__saved_genre%,symphony),$inmulti(%__saved_genre%,theme and variations),$inmulti(%__saved_genre%,vocal),$inmulti(%__saved_genre%,vocal music),$inmulti(%__saved_genre%,waltz)),
    $setmulti(genre,%genre%; Classical)
    $if($inmulti(%__saved_genre%,ballet),
        $setmulti(genre,%genre%; Ballet))
    $if($inmulti(%__saved_genre%,baroque),
        $setmulti(genre,%genre%; Baroque))
    $if($inmulti(%__saved_genre%,chamber music),
        $setmulti(genre,%genre%; Chamber Music))
    $if($or($inmulti(%__saved_genre%,choral),$inmulti(%__saved_genre%,choral symphony),$inmulti(%__saved_genre%,requiem)),
        $setmulti(genre,%genre%; Choral)
        $if($or($inmulti(%__saved_genre%,choral symphony),$and($inmulti(%__saved_genre%,choral),$inmulti(%__saved_genre%,symphony))),
            $setmulti(genre,%genre%; Choral Symphony)
            $setmulti(genre,%genre%; Symphony)
        $if($inmulti(%__saved_genre%,requiem),
            $setmulti(genre,%genre%; Requiem))
    $if($inmulti(%__saved_genre%,classical period),
        $setmulti(genre,%genre%; Classical Period))
    $if($or($inmulti(%__saved_genre%,concerto),$inmulti(%__saved_genre%,cello concerto)),
        $setmulti(genre,%genre%; Concerto))
    $if($or($inmulti(%__saved_genre%,contemporary classical),$inmulti(%__saved_genre%,modern classical),$inmulti(%__saved_genre%,neo-classical),$inmulti(%__saved_genre%,post-classical)),
        $setmulti(genre,%genre%; Contemporary Classical)
        $if($inmulti(%__saved_genre%,modern classical),
            $setmulti(genre,%genre%; Modern Classical))
        $if($or($inmulti(%__saved_genre%,post-classical),$inmulti(%__saved_genre%,neo-classical)),
            $setmulti(genre,%genre%; Post-Classical))
    $if($or($inmulti(%__saved_genre%,medieval),$inmulti(%__saved_genre%,gregorian chant)),
        $setmulti(genre,%genre%; Medieval)
        $if($inmulti(%__saved_genre%,gregorian chant),
            $setmulti(genre,%genre%; Gregorian Chant))
    $if($or($inmulti(%__saved_genre%,modernism),$inmulti(%__saved_genre%,impressionism),$inmulti(%__saved_genre%,minimalism),$inmulti(%__saved_genre%,post-minimalism),$inmulti(%__saved_genre%,postminimalism),$inmulti(%__saved_genre%,neoclassical),$inmulti(%__saved_genre%,neoclassicism)),
        $setmulti(genre,%genre%; Modernism)
        $if($inmulti(%__saved_genre%,impressionism),
            $setmulti(genre,%genre%; Impressionism))
        $if($inmulti(%__saved_genre%,minimalism),
            $setmulti(genre,%genre%; Minimalism))
        $if($or($inmulti(%__saved_genre%,post-minimalism),$inmulti(%__saved_genre%,postminimalism)),
            $setmulti(genre,%genre%; Post-Minimalism))
        $if($or($inmulti(%__saved_genre%,neoclassical),$inmulti(%__saved_genre%,neoclassicism)),
            $setmulti(genre,%genre%; Neoclassicism))
    $if($or($inmulti(%__saved_genre%,opera),$inmulti(%__saved_genre%,song)),
        $setmulti(genre,%genre%; Opera))
    $if($or($inmulti(%__saved_genre%,renaissance),$inmulti(%__saved_genre%,fantasia)),
        $setmulti(genre,%genre%; Renaissance)
        $if($inmulti(%__saved_genre%,fantasia),
            $setmulti(genre,%genre%; Fantasia))
    $if($or($inmulti(%__saved_genre%,romantic classical),$inmulti(%__saved_genre%,romantic),$inmulti(%__saved_genre%,rhapsody),$inmulti(%__saved_genre%,waltz)),
        $setmulti(genre,%genre%; Romantic)
        $if($inmulti(%__saved_genre%,rhapsody),
            $setmulti(genre,%genre%; Rhapsody))
        $if($inmulti(%__saved_genre%,waltz),
            $setmulti(genre,%genre%; Waltz))
    $if($or($inmulti(%__saved_genre%,score),$inmulti(%__saved_genre%,film score),$inmulti(%__saved_genre%,cinematic classical)),
        $setmulti(genre,%genre%; Score))
    $if($inmulti(%__saved_genre%,string quartet),
        $setmulti(genre,%genre%; String Quartet))
    $if($inmulti(%__saved_genre%,symphony),
        $setmulti(genre,%genre%; Symphony))
    $if($inmulti(%__saved_genre%,theme and variations),
        $setmulti(genre,%genre%; Theme and Variations))
    $if($or($inmulti(%__saved_genre%,vocal),$inmulti(%__saved_genre%,vocal music),$inmulti(%__saved_genre%,sacred vocal music)),
        $setmulti(genre,%genre%; Vocal Music)
        $if($inmulti(%__saved_genre%,sacred vocal music),
            $setmulti(genre,%genre%; Sacred Vocal Music))
# Add Adjacent Genres
$if($inmulti(%__saved_genre%,classical crossover),
    $setmulti(genre,%genre%; Classical Crossover))
$if($inmulti(%__saved_genre%,orchestral),
    $setmulti(genre,%genre%; Orchestral))
# BLUES GENRES
$if($or($inmulti(%__saved_genre%,blues),$inmulti(%__saved_genre%,blues rock),$inmulti(%__saved_genre%,british blues),$inmulti(%__saved_genre%,british rhythm & blues),$inmulti(%__saved_genre%,electric blues),$inmulti(%__saved_genre%,rhythm & blues),$inmulti(%__saved_genre%,soul blues)),
    $setmulti(genre,%genre%; Blues)
    $if($inmulti(%__saved_genre%,blues rock),
        $setmulti(genre,%genre%; Blues Rock)
        $setmulti(genre,%genre%; Rock)
    $if($inmulti(%__saved_genre%,british blues),
        $setmulti(genre,%genre%; British Blues))
    $if($inmulti(%__saved_genre%,electric blues),
        $setmulti(genre,%genre%; Electric Blues))
    $if($inmulti(%__saved_genre%,rhythm & blues),
        $setmulti(genre,%genre%; Rhythm & Blues))
    $if($inmulti(%__saved_genre%,soul blues),
        $setmulti(genre,%genre%; Soul Blues)
        $setmulti(genre,%genre%; Soul)
$if($inmulti(%__saved_genre%,british rhythm & blues),
    $setmulti(genre,%genre%; British Rhythm & Blues))
# CHILLOUT / AMBIENT / IDM GENRES
# All Adjacent Genres - No Parent
$if($inmulti(%__saved_genre%,ambient),
    $setmulti(genre,%genre%; Ambient))
$if($or($inmulti(%__saved_genre%,bristol sound),$inmulti(%__saved_genre%,bristol)),
    $setmulti(genre,%genre%; Bristol Sound))
$if($inmulti(%__saved_genre%,chillwave),
    $setmulti(genre,%genre%; Chillwave))
$if($or($inmulti(%__saved_genre%,downtempo),$inmulti(%__saved_genre%,chillout),$inmulti(%__saved_genre%,chill),$inmulti(%__saved_genre%,chill-out),$inmulti(%__saved_genre%,chilled electronica),$inmulti(%__saved_genre%,dub),$inmulti(%__saved_genre%,folktronica),$inmulti(%__saved_genre%,trip hop),$inmulti(%__saved_genre%,trip-hop)),
    $setmulti(genre,%genre%; Downtempo)
    $if($or($inmulti(%__saved_genre%,chillout),$inmulti(%__saved_genre%,chill),$inmulti(%__saved_genre%,chill-out),$inmulti(%__saved_genre%,chilled electronica)),
        $setmulti(genre,%genre%; Chillout))
    $if($inmulti(%__saved_genre%,dub),
        $setmulti(genre,%genre%; Dub))
    $if($inmulti(%__saved_genre%,folktronica),
        $setmulti(genre,%genre%; Folktronica)
        $setmulti(genre,%genre%; Folk)
    $if($or($inmulti(%__saved_genre%,trip hop),$inmulti(%__saved_genre%,trip-hop)),
        $setmulti(genre,%genre%; Trip Hop))
$if($inmulti(%__saved_genre%,drone),
    $setmulti(genre,%genre%; Drone))
$if($inmulti(%__saved_genre%,idm),
    $setmulti(genre,%genre%; IDM)
    $setmulti(genre,%genre%; Electronic)
$if($inmulti(%__saved_genre%,new age),
    $setmulti(genre,%genre%; New Age))
$if($inmulti(%__saved_genre%,synthwave),
    $setmulti(genre,%genre%; Synthwave))
# COUNTRY GENRES
$if($or($inmulti(%__saved_genre%,country),$inmulti(%__saved_genre%,country blues),$inmulti(%__saved_genre%,country pop),$inmulti(%__saved_genre%,country rock)),
    $setmulti(genre,%genre%; Country)
    $if($inmulti(%__saved_genre%,country blues),
        $setmulti(genre,%genre%; Country Blues)
    $if($inmulti(%__saved_genre%,country pop),
        $setmulti(genre,%genre%; Country Pop))
    $if($inmulti(%__saved_genre%,country rock),
        $setmulti(genre,%genre%; Country Rock))
$if($inmulti(%__saved_genre%,alternative country),
    $setmulti(genre,%genre%; Alternative Country))
# DRUM & BASS GENRES
# These Don't Parent with EDM Consistently so are Isolated
$if($or($inmulti(%__saved_genre%,drum & bass),$inmulti(%__saved_genre%,drum n bass),$inmulti(%__saved_genre%,atmospheric drum & bass),$inmulti(%__saved_genre%,jungle),$in(%_dirname%,Drum & Bass)),
    $setmulti(genre,%genre%; Drum & Bass)
    $if($inmulti(%__saved_genre%,atmospheric drum & bass),
        $setmulti(genre,%genre%; Atmospheric Drum & Bass))
    $if($inmulti(%__saved_genre%,jungle),
        $setmulti(genre,%genre%; Jungle))
# ELECTRONIC + EDM GENRES
# EDM is considered a parent Genre to all Electronic Dance Music
$if($or($inmulti(%__saved_genre%,electronic),$inmulti(%__saved_genre%,electronica),$inmulti(%__saved_genre%,chilled electronica),$inmulti(%__saved_genre%,electro),$inmulti(%__saved_genre%,leftfield)),
    $setmulti(genre,%genre%; Electronic))
$if($or($inmulti(%__saved_genre%,dj electronica),$inmulti(%__saved_genre%,dubstep),$inmulti(%__saved_genre%,edm),$inmulti(%__saved_genre%,house),$inmulti(%__saved_genre%,acid house),$inmulti(%__saved_genre%,acid),$inmulti(%__saved_genre%,acid-house),$inmulti(%__saved_genre%,breakbeat),$inmulti(%__saved_genre%,breaks),$inmulti(%__saved_genre%,broken beat),$inmulti(%__saved_genre%,deep house),$inmulti(%__saved_genre%,electro house),$inmulti(%__saved_genre%,epic house),$inmulti(%__saved_genre%,euro house),$inmulti(%__saved_genre%,french house),$inmulti(%__saved_genre%,progressive house),$inmulti(%__saved_genre%,industrial),$inmulti(%__saved_genre%,techno),$inmulti(%__saved_genre%,hard techno),$inmulti(%__saved_genre%,trance),$inmulti(%__saved_genre%,goa trance),$inmulti(%__saved_genre%,hard trance),$inmulti(%__saved_genre%,psy-trance),$inmulti(%__saved_genre%,psytrance),$inmulti(%__saved_genre%,progressive trance)),
    $setmulti(genre,%genre%; EDM)
    $if($inmulti(%__saved_genre%,dubstep),
        $setmulti(genre,%genre%; Dubstep))
    $if($or($inmulti(%__saved_genre%,breakbeat),$inmulti(%__saved_genre%,breaks),$inmulti(%__saved_genre%,broken beat)),
        $setmulti(genre,%genre%; Breakbeat))
    $if($or($inmulti(%__saved_genre%,house),$inmulti(%__saved_genre%,acid house),$inmulti(%__saved_genre%,acid),$inmulti(%__saved_genre%,acid-house),$inmulti(%__saved_genre%,deep house),$inmulti(%__saved_genre%,electro house),$inmulti(%__saved_genre%,epic house),$inmulti(%__saved_genre%,euro house),$inmulti(%__saved_genre%,french house),$inmulti(%__saved_genre%,progressive house)),
        $setmulti(genre,%genre%; House)
        $if($inmulti(%__saved_genre%,deep house),
            $setmulti(genre,%genre%; Deep House))
        $if($inmulti(%__saved_genre%,electro house),
            $setmulti(genre,%genre%; Electro House))
        $if($inmulti(%__saved_genre%,epic house),
            $setmulti(genre,%genre%; Epic House))
        $if($or($inmulti(%__saved_genre%,euro house),$inmulti(%__saved_genre%,french house)),
            $setmulti(genre,%genre%; Euro House))
        $if($inmulti(%__saved_genre%,progressive house),
            $setmulti(genre,%genre%; Progressive House))
        $if($or($inmulti(%__saved_genre%,acid house),$inmulti(%__saved_genre%,acid),$inmulti(%__saved_genre%,acid-house)),
            $setmulti(genre,%genre%; Acid House))
    $if($inmulti(%__saved_genre%,industrial),
        $setmulti(genre,%genre%; Industrial))
    $if($or($inmulti(%__saved_genre%,techno),$inmulti(%__saved_genre%,hard techno)),
        $setmulti(genre,%genre%; Techno)
        $if($inmulti(%__saved_genre%,hard techno),
            $setmulti(genre,%genre%; Hard Techno))
    $if($or($inmulti(%__saved_genre%,trance),$inmulti(%__saved_genre%,goa trance),$inmulti(%__saved_genre%,hard trance),$inmulti(%__saved_genre%,psy-trance),$inmulti(%__saved_genre%,psytrance),$inmulti(%__saved_genre%,progressive trance)),
        $setmulti(genre,%genre%; Trance)
        $if($inmulti(%__saved_genre%,goa trance),
            $setmulti(genre,%genre%; Goa Trance))
        $if($inmulti(%__saved_genre%,hard trance),
            $setmulti(genre,%genre%; Hard Trance))
        $if($or($inmulti(%__saved_genre%,psy-trance),$inmulti(%__saved_genre%,psytrance)),
            $setmulti(genre,%genre%; Psytrance))
        $if($inmulti(%__saved_genre%,progressive trance),
            $setmulti(genre,%genre%; Progressive Trance))
$if($inmulti(%__saved_genre%,alternative dance),
    $setmulti(genre,%genre%; Alternative Dance))
# FUNK GENRES
$if($or($inmulti(%__saved_genre%,funk),$inmulti(%__saved_genre%,funk rock),$inmulti(%__saved_genre%,jazz funk),$inmulti(%__saved_genre%,jazz-funk),$inmulti(%__saved_genre%,p-funk),$inmulti(%__saved_genre%,minneapolis sound)),
    $setmulti(genre,%genre%; Funk)
    $if($inmulti(%__saved_genre%,funk rock),
        $setmulti(genre,%genre%; Funk Rock)
    $if($or($inmulti(%__saved_genre%,jazz funk),$inmulti(%__saved_genre%,jazz-funk)),
        $setmulti(genre,%genre%; Jazz-Funk))
    $if($inmulti(%__saved_genre%,p-funk),
        $setmulti(genre,%genre%; P-Funk))
    $if($inmulti(%__saved_genre%,minneapolis sound),
        $setmulti(genre,%genre%; Minneapolis Sound))
$if($inmulti(%__saved_genre%,disco),
    $setmulti(genre,%genre%; Disco))
# FOLK GENRES
$if($or($inmulti(%__saved_genre%,folk),$inmulti(%__saved_genre%,chamber folk),$inmulti(%__saved_genre%,contemporary folk),$inmulti(%__saved_genre%,indie folk),$inmulti(%__saved_genre%,progressive folk)),
    $if($inmulti(%__saved_genre%,chamber folk),
        $setmulti(genre,%genre%; Chamber Folk))
    $if($inmulti(%__saved_genre%,contemporary folk),
        $setmulti(genre,%genre%; Contemporary Folk))
    $if($inmulti(%__saved_genre%,indie folk),
        $setmulti(genre,%genre%; Indie Folk))
    $if($inmulti(%__saved_genre%,progressive folk),
        $setmulti(genre,%genre%; Progressive Folk))
$if($inmulti(%__saved_genre%,acoustic),
    $setmulti(genre,%genre%; Acoustic))
$if($inmulti(%__saved_genre%,americana),
    $setmulti(genre,%genre%; Americana))
$if($or($inmulti(%__saved_genre%,lo fi),$inmulti(%__saved_genre%,lo-fi)),
    $setmulti(genre,%genre%; Lo-Fi))
$if($or($inmulti(%__saved_genre%,singer songwriter),$inmulti(%__saved_genre%,singer-songwriter)),
    $setmulti(genre,%genre%; Singer-Songwriter))
# HIP HOP GENRES
$if($or($inmulti(%__saved_genre%,hip hop),$inmulti(%__saved_genre%,alternative hip hop),$inmulti(%__saved_genre%,comedy hip hop),$inmulti(%__saved_genre%,new jack swing),$inmulti(%__saved_genre%,pop rap),$inmulti(%__saved_genre%,rap),$inmulti(%__saved_genre%,turntablism)),
    $setmulti(genre,%genre%; Hip Hop)
    $if($inmulti(%__saved_genre%,alternative hip hop),
        $setmulti(genre,%genre%; Alternative Hip Hop))
    $if($inmulti(%__saved_genre%,comedy hip hop),
        $setmulti(genre,%genre%; Comedy Hip Hop)
        $setmulti(genre,%genre%; Comedy)
    $if($inmulti(%__saved_genre%,new jack swing),
        $setmulti(genre,%genre%; New Jack Swing))
    $if($inmulti(%__saved_genre%,pop rap),
        $setmulti(genre,%genre%; Pop Rap)
        $setmulti(genre,%genre%; Pop)
    $if($inmulti(%__saved_genre%,turntablism),
        $setmulti(genre,%genre%; Turntablism))
# JAZZ GENRES
$if($or($inmulti(%__saved_genre%,jazz),$inmulti(%__saved_genre%,acid jazz),$inmulti(%__saved_genre%,afro-cuban jazz),$inmulti(%__saved_genre%,afro cuban jazz),$inmulti(%__saved_genre%,cuban jazz),$inmulti(%__saved_genre%,avant-garde jazz),$inmulti(%__saved_genre%,jazzstep),$inmulti(%__saved_genre%,orchestral jazz),$inmulti(%__saved_genre%,soul jazz),$inmulti(%__saved_genre%,swing)),
    $setmulti(genre,%genre%; Jazz)
    $if($inmulti(%__saved_genre%,acid jazz),
        $setmulti(genre,%genre%; Acid Jazz))
    $if($or($inmulti(%__saved_genre%,afro-cuban jazz),$inmulti(%__saved_genre%,afro cuban jazz),$inmulti(%__saved_genre%,cuban jazz)),
        $setmulti(genre,%genre%; Afro-Cuban Jazz)
        $setmulti(genre,%genre%; World)
    $if($inmulti(%__saved_genre%,avant-garde jazz),
        $setmulti(genre,%genre%; Avant-Garde Jazz))
    $if($inmulti(%__saved_genre%,jazzstep),
        $setmulti(genre,%genre%; Jazzstep))
    $if($inmulti(%__saved_genre%,orchestral jazz),
        $setmulti(genre,%genre%; Orchestral Jazz)
    $if($inmulti(%__saved_genre%,soul jazz),
        $setmulti(genre,%genre%; Soul Jazz)
    $if($inmulti(%__saved_genre%,swing),
        $setmulti(genre,%genre%; Swing))
$if($or($inmulti(%__saved_genre%,nu jazz),$inmulti(%__saved_genre%,nu-jazz),$inmulti(%__saved_genre%,neo-jazz)),
    $setmulti(genre,%genre%; Nu Jazz))
Pplease read the “Part 2” post for the second half of the script.
